TBI->TPI swap almsot ready to go
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Well I bought myself a TPI off of an 87 IROC.
I have everything except the wiring harness and the lower part of the air box.
THe guy I bought it from is going to help me put it on. Any problems that I should be aware of that you have run into during the swap that I should be aware of?
Also best place to get the harness? Summit of Jegs or something, painless wiring?
Any and all help will be most appreciated.
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
160 stat,
Car: 92' RS
Engine: LO3
Ah yes especially the question, which I am sure I already know the answer to:
DO I have to change the damn fuel pump?
160 stat,
160 stat,
YES you have to change the fuel pump. It's a pain in the *** if you do it the hard way. On my car I peeled the carpet up in the trunk, cut a hole, and made a panel with szus fasteners.
Also, send your stock TBI harness to Howell. Go to www.howell-efi.com. It costs $350 for the conversion, takes two weeks, and everything from in dash functions to emissions equipment will be operable. DO NOT, I repeat, DO NOT BUY A PAINLESS!! They are made for custom applications, not factory style swaps.
Any questions, email me. I've done the swap.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
The_Phoenix
Sep 3, 2015 10:56 PM
Sanjay
Aug 12, 2015 03:41 PM
