is LB9 a real high output
Old Oct 23, 2007 | 01:07 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
on the rpo codes it says lb9 is a high output motor why is that ? is it cuz its a tpi motor? or some kind of cam besides peanut ?
Old Oct 23, 2007 | 01:45 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: is LB9 a real high output
Yes, in the sense of it having highest horsepower output in the GM 305 engine class in its era, and it sounded good for marketing. other than that its considered a low output by most people.
Old Oct 23, 2007 | 11:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its "High Output" compared to the other 305's GM used in thirdgens (LG4, LO3, L69) but really the only LB9's that should be called "high output" would be the 89-92 ones with 5-speeds and dual-cats.
Old Oct 23, 2007 | 11:42 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
85's only had 15hp less than the dual cat M5 cars, so that would be considered HO as well.
junior419
Apr 7, 2025 11:35 AM
gta_knight
Sep 23, 2015 04:59 PM
WhteRbt
Sep 21, 2015 09:48 AM
dimented24x7
Sep 17, 2015 06:58 AM
TrevinE
Sep 14, 2015 03:20 PM
