Whos thinks they know about the 87 305 5.0 TPI
Car: 1987 IROC Z28 Camaro
Transmission: Stock
Axle/Gears: Stock
I have alot of questions for a rebuild or upgrade, i have a 87 305 5.0 TPI auto, with hedders and new exhaust. First of all my car runs like ****. 1. when first start idle is high . 2. loud noise when shifing into drive 3.loud vibrations in front passenger when in reverse.
How can i fix this car?
Whats the right way about doing this, is a 350 rebuilt motor a bad idea?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Whos thinks they know about the 87 305 5.0 TPI
Whew!
Start at the beginning. Do you have a repair manual?
I recommend the Chilton's total car care manual for 82-92 Camaro. Great book.
If you don't have that then you are not ready to begin.
High idle with efi usually means vacuum leak somewhere. That also makes the car run like ****.
Loud noise wnen going into drive usually means broken transmission mount.
This also makes vibrations in reverse.
Get the manual and good luck to you!
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
