Question about the 89 chip being better
Old Apr 12, 2001 | 08:56 PM
R.O.B.'s Avatar
If the 89 chip is better, then why is the LB9 auto's rated at the same horsepower (190) as my 86 is? Wouldn't a better chip equal a few ponies?
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Apr 12, 2001 | 09:18 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
It's the cam and the choked up exhaust that throttles the 86-89 LB9.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Its better for mods, if the car is stock and is going to stay that way, u can just leave the 86 chip in it and it will work good.
U wouldn't want the 9th injector with this chip because there wasn't a 9th injector in 89 and the chip makes up for this and uses the the other injectors instead, so u wouldn't want the ECM doing that and the 9th injector too.
[This message has been edited by IROCZTWENTYGR8 (edited April 12, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
