91' lo3 to speed density.
Old Apr 2, 2001 | 01:17 AM
442guy's Avatar
do you know if the stock 91,92, engine harness will plug right into the dash harness of a throttlebody injected car?
well, will it WORK is what im asking.
Old Apr 3, 2001 | 11:24 AM
nestz28's Avatar
If you are asking if your existing harness will work with TPI, I don't think so.
Old Apr 3, 2001 | 01:21 PM
Scott C's Avatar
I just swapped the TBI harness out of my '92 RS for a brand new GM TPI harness. The TBI & TPI harnesses are different in several ways.
I think your question is about the engine harness connecting to the dash harness, right? If so, the TPI harness works just fine. It plugs into the same "junction block" on the driver's side firewall and also plugs into the same connectors under the dash on the passenger side at the ecm.
Let me know if you have any other questions as I just did this swap 3 days ago.
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 roller rockers, Edelbrock Hi-Flow base, runners & 52mm TB, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Apr 5, 2001 | 03:00 PM
IROCZ88's Avatar
I'm starting to sound like a Howell representative now. lol Send it to him. It takes two weeks for the conversion and costs $350 which is cheaper than a new GM. www.howell-efi.com
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 13, 2001 | 01:26 AM
Lov2xlr8's Avatar
Sounds to me like you have broken rotator splint, or maybe you have small *****? maybe, you should take the engine side of the TPI and plug it into the interior sid eof the TBI harness, and see if all the wires and their colors line up, the Gm wiring changed in groups, up to 86, 87 t0 89 , and 90, then 90 to 92, i thik, but he pin is the wires will probally be in different spots and since the years are different, thngs like tach leads and other sensors might have different colors. Youn need to compare both harnesses in full . i will lend you my chiltons book, beer, my sister and a fleet of mexicans to sort it all out, ps the mexicans are purly for entertainment value as do they not posses any mechcanical skills.
Old Apr 14, 2001 | 01:19 AM
442guy's Avatar
dont listen to lov2xlrate, just because i helped hime throw an 8 cyl in his camaro he thinks he knows everything now. by the way ROB your a chevy gini.
Elephantismo
Feb 13, 2019 12:51 AM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
