plug wires
Old Apr 13, 2001 | 03:12 PM
IROCZ88's Avatar
plug wires
I have TES headers and I don't like the way the plug wires route. What's the best wires to use and best way to run them. Pictures would be helpfull. Thanks.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 13, 2001 | 06:23 PM
Dan87IROC-Z's Avatar
What I had to do was get a set of Accel 300+ race wires and make them myself. This way, with a little planning ahead, you can get all your plug wires perfect and you won't have any problems with them comming into contact with the headers. A set of wires will cost you about $60 and expect to spend a good hour or two measuring, planning and then acctually constructing the wires. Sorry I don't have any pictures.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Apr 14, 2001 | 01:33 PM
IROCZ88's Avatar
Thanks, I just ordered MSD 8.5 universal so I can make them to length. They were $80, but I figured MSD's were worth it.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
