Can you delete the 9th injector on a pre88 intake to make it work on a 92 5.7TPI?
Old Apr 15, 2001 | 12:23 PM
The Man's Avatar
what other things need to be change to make it work?
Old Apr 15, 2001 | 01:31 PM
leirch's Avatar
Well assuming your going to run the 92 tpi harness and computer(speed density setup). You can just plug the hole that was used for the 9th injector and go on your way as if it wasn't even there.
Brendan
Old Apr 15, 2001 | 02:27 PM
The Man's Avatar
I have a 92 set up. i was looking at a aftermarket base that was for a 85-88 set up. I wasn't sure if that was all you had to do(plug the hole).
thanks alot
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
