MAT Relocaton??
Old Apr 15, 2001 | 06:51 PM
irocrob's Avatar
Car: 1985 Chevrolet Camaro IROC
MAT Relocaton??
TPIS states that if you move the manifold absolute temp sensor to just before the TB, you get much better throttle response. This seems right to me because the air is obviously cooler at this point. They also use the 92 & up MAT sensor, why, I do not know yet. Has anyone did this yet, and did you notice any difference? Or, is this just a waste of time and $35.
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
Old Apr 15, 2001 | 09:26 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I did it and throttle response improved and it didn't cost me $35.All I did was splice the wires long enough to reach the air ducting in front of the MAF.I soldered the spliced wires and there's a plate w/ a hole in the air duct on the drivers side.
BD3
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,Dan Burk ported intake system,,March
pulleys,Accel 8.8wires,ign.mod,Crane PS-91 coil,Crane HI-6S ign.box
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod,mac subframe connectors
"The more I learn about women,the more
time & money I spend on my IROC"
Old Apr 16, 2001 | 12:22 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You need to look up the discussion that I had with a couple other members about that MAT sensor relocation last week.
The jist of what we came up with is that the MAT on a MAF car only controls the EGR valve cutoff and NOT the fuel or timing control of the engine. Therefore, moving the sensor on a MAF car is not going to give better performance and it is most likely a bad idea.
On a SD setup, the moving of the MAT/IAT will bring great gains - if the EPROM is made to work with it (the ECM will be getting waayyy different readings than it is used to if you move the sensor).
Old Apr 16, 2001 | 12:35 AM
Vader's Avatar
Rob,
If you want to do it, check this file for instructions:
MAT Sensor Relocation.pdf
You'll need Adobe Acrobat reader to access the file. (See below.)
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 16, 2001 | 02:04 AM
Raymond 5.7 89 Formula's Avatar
Rob, I was thinking about doing this also a couple of weeks ago. But after reading all the info about this lately I have changed my mind. If I had a SD system I would do it. Glenn has been doing some research on this lately. If you feel your car is running too lean then it might help. Or maybe if you put in a bigger duration cam with a custom chip. But with my mods that are like your yours I would leave it alone unless Glenn comes up with some different info.
SLP 1 5/8 Headers,ATR catback exhaust,SLP cold air box,Crane 1:6 roller rockers,Bosch plugs and MSD wires,MSD Coil,Fastchip,Borg Warner 9 bolt 3:27,Corvette Servo,ROH ZS 17X9.5 Goodyear GSC,s 275/40/17
Old Apr 16, 2001 | 11:51 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It's a waste of money on MAF cars as I cannot find anything in the machine code for MAF cars that suggests that the ecm uses it for any correction. Though it is a cool thermometer if you have a scan tool running.
Old Apr 16, 2001 | 08:51 PM
irocrob's Avatar
Thanks for all the info guys. I will take it all into consideration. doesn't seem to be a good idea at this point in time!!
Rob Kowalski
1992Z28!
Nov 19, 2015 07:33 AM
ULTM8Z
Oct 2, 2015 01:25 PM
F-body-fan
Sep 19, 2015 09:02 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
