Dreaded Code 32
Old Apr 9, 2001 | 11:29 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Dreaded Code 32
Ok, what would cause a code 32 immediately on startup??
Troy Backus
Old Apr 10, 2001 | 01:07 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I have the same code on my 86. Code 32 could be 3 things: EGR Valve, Barometric Pressure Sensor Circut Failure, or a Vacumn Leak of some sort. My problem is that when the engine is cold, the car wants to stall(and does)very badly. Sometimes, it shakes violently. But my engine light only comes on when i am doing 65-75mph on a long drive..and stays on anywhere from 10min to 10 miles and then goes off...and never comes back on again. But as far as code 32 is concerned, its gotta be one of the above problems. Check those out. Good luck.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
OTHER RIDE:
1998 C5 6Spd. Corvette
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Apr 10, 2001 | 06:23 AM
scanman717's Avatar
Engine: LB9
I guess I left out that I just replaced the 2 vacuum lines from the EGR Valve. I have triple checked to make sure they are on and in the correct place.... The old lines were broke and I was getting 32 only periodically like PHantom describes, now I get it immediately on startup.... Could I have damaged the valve from putting the vacuum lines on?? They were really tough to get on.
Troy Backus
92 Camaro Z28 Convertible
Old Apr 10, 2001 | 08:53 AM
Pino91Formula's Avatar
Well , I have been fighting with this since October, You didnt damage the valve by replacing the vacume lines , but thst a great place to start , I would try replacing the egr valve it self. It shouldnt be coming on right away after start up , the egr vavle doesnt start working until the car is moveing at a steady speed, like Highway driving, It could also be carbon build up in you intake passages. I see your car is a 92 ,, mine is a 91 , and i just got it back on ,, i think my problem is my exhuast is to free flowing , have you done any exhuast modifications of any kind?
Old Apr 10, 2001 | 09:11 AM
scanman717's Avatar
Engine: LB9
Yep, I did put a flowmaster 3" exhaust. I also just finished porting the plenum, and cleaned out the egr passages in the plenum. What confuses me is that when I had broken EGR lines I only got the 32 code after running for a while... I am almost tempted to take it off again and see what happens.
Troy
Old Apr 10, 2001 | 11:56 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Yes, mine ONLY comes on when i am traveling at a constant speed, and on a long trip. I also have a modded exhaust, with a random tech cat(see sig)....i just hope this doesnt corrupt the EGR or anything else in any way.
OTHER RIDE:
12/14 Options
Stock(for now)
Old Apr 11, 2001 | 03:00 PM
well I'v been told that a negative pressure egr system can be converted to a positive system which would not need back pressure from the exhuast , im probably going to have it done next month or so , so i will let you all know what happens , I have replaced everything some things twice even and still get it , so this is my last resort.
Old Apr 11, 2001 | 03:28 PM
scanman717's Avatar
Engine: LB9
The odd part is that I put the exhaust on almost a year ago and this just started...
3" Flowmaster
Ported Plenum
Old Apr 11, 2001 | 05:03 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
EXACTLY! I have had my random cat and flowmaster on for OVER a year and this just started now....
OTHER RIDE:
12/14 Options
Stock(for now)
Old Apr 12, 2001 | 08:15 AM
Thats exactly what i did also , but the thing with performace exhuast , as they get older abd break in they flow better , and usually get louder, so thats why it doesnt affect anything until a year or so .
Old Apr 12, 2001 | 01:08 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
If your SEL comes on Imediately at startup with a code 32, your EGR diagnostic switch is bad. (this is the little feller that screws into the base of the EGR valve. Single wire connector) The only time EGR code will set as soon as you start up is when the switch is telling the ECM that EGR is open.... Generally implies a failed switch.
Old Apr 12, 2001 | 02:51 PM
Desert86Roc's Avatar
You probably just have excessive carbon buildup..... I had the same problem, and took the plenum off to take a look...both the egr passages were 75% blocked... So a good plenum cleaning with carb cleaner, and then spray the heck out of the runners, and you should be back and running....I did not even remove the EGR valve (which can be a pain with the sensor in the way), and really dumped a lot of carb/fuel injection cleaner down the runner EGR holes..... It would also be a good time to pour some GM Top Engine Cleaner down your runner openings.
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
Old Apr 13, 2001 | 02:58 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
I think my prob is more like the EGR itself is bad...anyone have a pic of what one looks like? And a diagram of where it goes on a 305 TPI engine? Thanks.
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
12/14 Options
Stock(for now)
[This message has been edited by PhantomTPI (edited April 13, 2001).]
Old Apr 13, 2001 | 06:14 AM
86TransAmTPI's Avatar
[QUOTE]Originally posted by Desert86Roc:
[B]You probably just have excessive carbon buildup..... I had the same problem, and took the plenum off to take a look...both the egr passages were 75% blocked... So a good plenum cleaning with carb cleaner, and then spray the heck out of the runners, and you should be back and running....I did not even remove the EGR valve (which can be a pain with the sensor in the way), and really dumped a lot of carb/fuel injection cleaner down the runner EGR holes..... It would also be a good time to pour some GM Top Engine Cleaner down your runner openings.
I was wondering,after having so much carb/fuel injection cleaner dumped in the runner EGR holes and also dumping GM Top Engine cleaner down the runner openings,did the car have a hard time starting up,cause all i can imagine is all the carbon and chemicles sitting at the bottom and covering your plugs.Thanks,Al in NJ
Check out My Trans Am:
http://hometown.aol.com/italianknight178/index.html
Old Apr 13, 2001 | 09:10 AM
Ron Mullins's Avatar
I just got a code 32 this morning. Replaced the EGR valve about a year ago. I'll check out the vac lines and that little wire and let you know what I find if anything.
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, MSD6AL, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Apr 13, 2001 | 10:23 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by scanman717:
Troy Backus
</font>
A failed or disconnected temperature sensor can cause an immediate DTC. A failed EGR solenoid can as well.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 13, 2001 | 11:19 PM
Bob Wooten's Avatar
Phantom,
my buddy has a TA that was doing the same thing that yours is doing. he tried going down the road & then yanking it off the road to punch the ALDL to see if he could not get the code but no luck. he ended up borrowing a scan tool from another budy of mine & had it sitting on the seat next to him. as soon as the CEL (or SES) light came on he picked it up & saw that the code was for O2 sensor. He did not think that possible as he changed it 4K or 5K miles ago. but he changed it anyway. He has not had any more CEL's since.
HTH's, worth a try if you dont have a scan tool.
BW
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Apr 13, 2001 | 11:24 PM
Bob Wooten's Avatar
Oh, & as for the shaking & wanting to die thing, I bet that if you use a scan tool that you might find that it stops shaking & starts behaving as soon as it warms up & goes into CL (or gets close to it). check to see what your IAC counts are. Mine were in the 190 range & it was doing a simlar thing. last weekend i took it appart & found it VERY dirty & crudded up. I cleaned off the pintle & seat & put it back together. set the minimum idle & now she purrrrrrrrrrrrrrrs.
just a thought.
BW
Bob Wooten
71 Camaro, 91 EFI
Old Apr 14, 2001 | 08:03 AM
scanman717's Avatar
Engine: LB9
First, let me say thanks to you guys. You have been a wealth of info.
Here's what I know up to this point... The Code 32 has stopped on startup. it now only comes on after highway driving. I do have a scan tool and verified that all parameters are in acceptable ranges. I forgot that I had disconnected the battrery and the computer needed to "re-learn" everything, and the car since purrs like a kitten.
My factory service manual suggests that I could have the vac lines pushed on too far, thereby causing a blockage. I am going to try this later today, as this is the last thing I replaced before all this crap started.
I will keep you posted....
Troy
Old Apr 14, 2001 | 10:19 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i've done to engnes in my cars one in an 87 iroc 350 5 speed and the other in an 87 ta in boh cases a performance exhaust was installed all an egr system is is an exhaust gas recirculatio device to burn off any residual fuel mine has been omitted since the swap and i never have gotten a code for it yet.try getting a blockoff plate and take it off your car iit wont hurt the engine!
Old Apr 17, 2001 | 10:17 AM
Well Im not the only one fighting with this , well two weeks ago my light came on at a odd time about a mile and a half from my houe , it snever done that,. I chalked up to the fact that i didnt clear the codes from the computer. I have since then done that , and i have had no problems . since i put the $20 special muffler on to test my theory , i will be putting on a new ypipe with catco cats and the slp exhuast system in the next few weeks hopefully it takes care of it , if not im going to have my egr converted to a positive valve system.
Old Apr 17, 2001 | 01:25 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Bob...
Thanks for the input. Unfortunetly, I do not have a scantool so i cannot find out what my IAC counts are. Nor can i afford a scantool right now...all I've got is that $20-dollar code reader from Walmart. But you have helped me to consider other things as well...thank you for your suggestions. I am going to get my EGR valve and replace it, reset the computer, and see what happens. Hopefully, i wont have a problem after that. Thanks again. Vader-thankx for the pic!
OTHER RIDE:
12/14 Options
Stock(for now)
[This message has been edited by PhantomTPI (edited April 17, 2001).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
