Trick Flow heads
Old Oct 29, 2007 | 06:23 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Trick Flow heads
http://www.trickflow.com/product/che...3degree175.asp
Anybody have any experience with these heads? Specifically, whether or not they have an exhaust crossover so I can keep my EGR? I emailed then called Trick Flow and got conflicting answers. Also, for my application, a 305 TPI, (Save it. I'm not going 350/383 at this point in time. ), my choices are these or World Products S/R's. From what I've been able to find out so far, the Trick Flows flow much better and would have the weight saving advantage of aluminum, compression advantage notwithstanding. Yes? No? Why? Thanks!
PS Here's the cam I'm looking at: http://store.summitracing.com/partde...5&autoview=sku
Plus a TPIS Bigmouth base/runners and a set of headers. Good?
Old Oct 29, 2007 | 06:56 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Trick Flow heads
I really know next to nothing about this stuff, but it looks like all the heads on that chart are for 327s or bigger. I am also looking for a set of heads and cam so I am very interested in this too.
Old Oct 29, 2007 | 09:35 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i dunno i looked at there pdf chart and for the 262-305 styled small combustion head it says 1.99intake and 1.23exhaust valves, sounds insane like wtf??????
anyways trickflows usually are the next best thing to afr's and i'd have to say that a 175cc volume would be pretty nice. + aluminum = sweet.
what kind of a price do those run, any idea?
anyways i'm sure the valve sizing on the pdf is wrong and the 1.94/1.5 valve sizing on the page is right but, still thats pretty wierd.
Old Oct 30, 2007 | 04:23 AM
watajob's Avatar
Car: 92 T/A 'vert
About $1100.
Old Oct 30, 2007 | 06:03 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Originally Posted by watajob
About $1100.
I sure hope there are some cheaper heads out there that improve horse power
Old Oct 30, 2007 | 06:10 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
About $1100.
about what i would figure coming from trickflow but, still thats a viable upgrade if you realy want to go all out with your 305 it seems.
Old Oct 30, 2007 | 11:50 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Based on the other Trick Flow heads I have seen (the 195 version) yes they should have the exhaust crossover passage for the EGR.
Not a chance. All the good heads cost more than $1000. I have heard the Patriot aluminum heads are around $800, though. No experience with them.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
