Crane powermax cam for L98?
Old Oct 29, 2007 | 03:24 PM
tmviper's Avatar
cam specs
lift in/ex: .452/.465 w. 1.5 rr's, .482/.495 w/1.6rr's
dur @ .050" : 214/220
ive got 1.6 rr's on my L98 in my 90 bird, just wondering if anyone has ever tried this cam before. if so, how does it sound and perform? and how did your power brakes react? thanx
Old Oct 29, 2007 | 04:36 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
Re: Crane powermax cam for L98?
i dont personally have any experience with that cam but i have a bigger one in my lb9 and my brakes were not effected at all so im sure you will be fine with that
Old Oct 29, 2007 | 09:07 PM
tmviper's Avatar
what type/specs are your cam?
Old Oct 30, 2007 | 08:38 AM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
witht the 1.6 rr i think its like 536 lift and something like 235 duration, im not exactly sure the cam # is in my sig, its a comp extreme efi cam
Old Oct 30, 2007 | 11:34 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The CompuCam 2032 is a smaller cam by today's standards, but its one of the largest that might still work with the stock computer programming. I dont recommend anything larger than 210 with stock programming.
I did a custom chip on a car a few years back with that cam, SuperRam intake, SLP 1 3/4" headers, and an automatic that made 295 RWHP and I forget the torque, probably something like 360. He wasnt happy and swapped to the LT4 hot cam and it made another 15-20 horsepower.
If you're using the stock heads with this cam and 1.6 rockers you'll be pushing the limits and might be hitting the valve guides. Stock heads are good to about .480 lift with the stock springs. You should change the springs anyway with a cam swap. I recommend the Manley 22410-16 springs and 23652-16 retainers. That'll get you enough clearance to run up to .520" lift.
Old Oct 30, 2007 | 11:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
thats a nice mild cam. should improve performance over stock L98 cam by a good 20-25whp i'd say. is enough cam to get into the 12's provided everything else is there.
if you do want to keep 1.6 rockers, get a shim kit and offset locks and those springs suggested above...good choice and it will give you extra clearance needed
Old Oct 30, 2007 | 04:18 PM
tmviper's Avatar
Orr89Rocz, i will be prob be getting Dart iron eagle heads with that cam, and do the two together, will i still have get a shim kit and offset locks? the heads come assembled with 2.02/1.60 valves, which is beautiful, and it allows up to .520 maximum lift, so im not to worried about that.have you ever had this cam in your car(s)? if wo, how did it sound? although i dont want to put in a crazy cam, but id still like to have a cam that makes the car shake a little at idle, and has a nice lope to it..
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
