IAC cleaning. Possible screw up?
Old Apr 14, 2001 | 10:11 PM
Night Hawk's Avatar
I don't know if I messed up or not today. I took my IAC apart to be cleaned and there seemed to be a tiny white plastic o-ring at the end of the threaded pintle. The ring broke in 4 pieces. Is this o-ring vital? I cleaned the inside passageways with heavy-duty brake cleaner which seemed to work well but is it dangerous to the motor (throttle body off the car).
Also when threading back in the pintle, must it fully thread in and does the grooves have to be lined up with two side guides?
Any other concerns I should be aware of?
Old Apr 17, 2001 | 12:18 PM
Night Hawk's Avatar
no one clean out their IAC?
Old Apr 17, 2001 | 12:40 PM
Steve89GTA's Avatar
I know how you feel dude...
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Apr 17, 2001 | 07:24 PM
Guest
Guest
Posts: n/a
Ive cleaned it, but never taken it apart. If you have it threaded back in ok, make sure its all the way down and I hope it works ok. Im not sure about the o-ring, but I'll bet its there for a reason.
3rd gen money
Oct 11, 2019 09:57 PM
LT1Formula
Oct 8, 2015 08:34 PM
thejimsterz28
Sep 30, 2015 08:52 PM
