LT1 cam in 91 305 tpi
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
I have a 91 z28 vert with a 305 tpi/auto tranny. There was oil getting in the coolant, so I suspect a head problem. Me and my buddy tore the upper end of the engine apart tonight, and got to thinking that heck, we came this far; why not go a little furthur and throw in a cam? He has a stock LT1 cam he got with a converted LT1 intake from a guy on here he's willing to give me. What I want to know is if this will make any difference over the stock cam, and whether or not I need a new chip (it's speed density). Thanks for any advice you may have.
Kevin
Kevin
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: LT1 cam in 91 305 tpi
It's damn near the same cam but with a little more lift.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Put it in there, you wont have a problem. It would be like adding 1.6 rockers to your stock cam. But, you cant add 1.6 rockers to the LT1 cam with stock heads, that's too much lift.
Sanjay
Aug 12, 2015 03:41 PM
