TPI Fuel Pum Regulated Down for Temp Carb Supply
Old Oct 30, 2007 | 04:11 PM
jimchristiansen's Avatar
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
I'm installing a complete 350 in my vehicle. Due to engine location and interference, the mech fuel pump can not be retained. I have a TPI system to install in the spring when it warms ups (no garage yet) and will need to purchase a higher pressure electric fuel pump for it.
Can I skip the low pressure carb type electric fuel pump and install an inline high pressure pump now and just regulate it down?? Would this restricted flow damage the pump?
Thanks, Jim
Old Oct 30, 2007 | 04:27 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: TPI Fuel Pum Regulated Down for Temp Carb Supply
It shouldnt restrict the flow if you use a regulator. It would actually flow more.
Mallory (p.n.: MAA-4309)
Grant (p.n.: 132-171021)
There you go.
MustangBeater20
Oct 29, 2022 09:20 PM
beachrodder
Aug 25, 2015 08:05 AM
wayshegoes
Aug 17, 2015 12:00 PM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
