Bad idle, rolls, running rich, So lost HELP
Old Nov 1, 2007 | 07:50 PM
BLUE_IROC's Avatar
I have a 1989 Camaro IROC 5.7, no mods to engine, the car had sat for about a month without starting, got it registered and found it has a really bad idle, also seams to have lost power, took the car to a local mechanic, he hooked it up to his scan tool and found the car was running rich. I thought the car might have some carbon buildup or sludge in the throttle body, removed throttle body and cleaned it thouroughly, no change. Took of and replaced the IAC for $70 no change tried running techron through no change, diconnected maf, sprayed the whole intake/vaccum system, replaced the gasket between the throttle body and the plenum, nothing worked... PLEASE HELP... she has 88,000 miles, and some mods here and there, im just so lost
Old Nov 1, 2007 | 08:09 PM
1bad86z28's Avatar
Car: 86 I.R.O.C.
Engine: 40 over TPI 305
Axle/Gears: 3:73
Re: Bad idle, rolls, running rich, So lost HELP
Check your fuel pressure regulator.
Old Nov 1, 2007 | 10:20 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Also check your timing.
Old Nov 2, 2007 | 01:55 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You're just throwing parts at it. Time for the basics. Check the fuel pressure, plugs, and wires. Make sure all the injectors are firing. Check timing and vacuum. A fouled plug, bad wire, bad injector, and a dozen other things could be the cause.
Old Nov 2, 2007 | 08:49 PM
jamesbob02's Avatar
Car: 92 Z28
I assume you're not getting any codes?
In addition to all the above mentioned, make sure your TPS is set correctly.
MustangBeater20
Oct 29, 2022 09:20 PM
backtothe80s
Sep 5, 2015 12:39 AM
camaro71633
Sep 1, 2015 10:24 AM
db057
Aug 22, 2015 08:17 PM
squiggy2
Aug 9, 2015 09:30 PM
