hypertech???
Old Apr 19, 2001 | 10:57 PM
88ta_stangkilla's Avatar
hypertech???
i just bought a hypertech fan switch for my 88 ta...i just replaced the thermostat which is stock 195 degrees...now with the fans coming on at 180 degrees will i still be ok??
Old Apr 19, 2001 | 11:50 PM
BlueZ89's Avatar
Nope....think about it...the stat doesnt open till about 195 degrees but by 180 degrees the fans are already on so by now the stat is open and coolant is running through the radiator the fans are still running and cool the coolant to 195 degrees then the stat is closing and the coolant is still around 190 degrees but the stat is closed and the fan swich in the head is still seeing 190 degrees and keeping the fans on but coolant is not flowing through the radiator anymore to cool the heads so the switch in the head will never see 180 degrees again after the car warms up. Therefore the fans will run all the time. I would search the boards for the GM part number for the 170 degree stat....its not to cold for the ECM and is a lot cooler than stock.
Old Apr 20, 2001 | 01:25 PM
chret's Avatar
I think that was the longest run-on sentence I have ever seen. Take a breath.
'92 Camaro Z28 5.7L L98(B4C) 25th Anniversary Edition Holley Air Foil, MSD Coil and Ignition, Dual K&N Air Filters with modified intake, TCI StreetFighter 700R4, TCI Saturday Night Special Torque Converter, TPIS Aluminum Drive Shaft, Performance Resources Computer Chip, No Cats, True dual exhaust with dual Flowmasters,
Old Apr 20, 2001 | 03:59 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I can get my car to run 175 degrees with a 160 degree stat and my adjustable fan switch(ECM only needs 173 degrees to work properly)
<font face="Verdana, Arial" size="2"> Originally posted by BlueZ89:
but the stat is closed and the fan swich in the head is still seeing 190 degrees and keeping the fans on but coolant is not flowing through the radiator anymore to cool the heads so the switch in the head will never see 180 degrees again after the car warms up. </font>
That statment is not necessarily correct either! The coolant doesn't have to be "flowing" through the radiator to cool! The fans will simply cool the coolant that is sitting IN the radiator! Then when the engine gets hot enough again, the stat will open and let that "cooled" coolant in from the radiator! But I do agree that it's kinda pointless to have a 180 fan switch with a 195 stat! For optimal cooling just add a 180 stat in there....the 180 is fine for our cars! Or spend a little extra on the 170 from GM!
Old Apr 21, 2001 | 11:42 PM
Kevin S's Avatar
You will be fine!Just the fans will run constantly.It would be no different then if you were to wire the fans to run as soon as you turn the key.It will help your temp from going up and down.
Since my dragon pic won't work I'll have to live with this...
Kevin S
89 RS w/2.9
modded some but not heavily
KO1
16
Oct 15, 2015 05:00 PM
NBrehm
Aug 25, 2015 11:49 PM
vortech305
Aftermarket Product Review
Mar 17, 2001 09:41 PM
85F-body
Jan 15, 2001 06:42 PM
My90Iroc
Dec 18, 2000 08:46 PM
