89 350 cam in a 87 305 tpi
Old Nov 4, 2007 | 10:17 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Ive got an 87 305 tpi i have a 89 350 cam i would like to put in my 305(check out cam specs in technical articles) but the 305 auto in 87 had a very small lift and 108sep the 89 has higher lift but 117sep. Will i be able to run this cam with out changing proms or injectors
Old Nov 5, 2007 | 02:26 AM
Pat Hall's Avatar
Re: 89 350 cam in a 87 305 tpi
I'm no expert, but I would think it's feasible. The MAF TPI systems are pretty tolerant when it comes to cam changes, and the factory L98 cam isn't a massive difference from the cam you have now. At the least, an adjustable fuel pressure regulator might not be a bad idea. On the 90-92 speed density cars, which are more sensitive to cam changes, GM put the exact same cam in both the 305 and 350 TPI's.
Old Nov 7, 2007 | 01:30 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
yes thats doable, but if ur going thrue the trouble of swapping cams, go bigger and better. even a stock lt1 would be more beneficial.
Old Nov 7, 2007 | 11:51 PM
Pat Hall's Avatar
Yeah, if you're interested, I've got a LT1 cam out of a 94 T/A in great condition. The 93-94 LT1 cams have the standard length dowel pin, so you don't even have to shorten it. It's a direct fit in the 87-92 305/350 motors. Shoot me a PM if you want it. Pat.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
