AFR 190'S or 195'S??
Old Apr 24, 2001 | 02:22 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I'm building a .060 over 350 forged crank, h beam rods, forged pistons, ZZ-9 cam, retro fitted to a roller set up. Planning on using an ACCEL, or TPIs base and runners, and 52mm TB. Should yeild about 10.5 10.6 to one compression with 74 cc heads. I was wondering which to go for. I don't want to loose any low end torque by goning too big on the intake runner size. But I don't want to choke the motor. My guess is 190's but I'd like to get some opinions..
86 IROC-Z soon to be 350, 700r 2500 stall, 3.42 geared 9 bolt.
Old Apr 24, 2001 | 07:00 AM
Guido's Avatar
Car: 2000 Trans Am
The only difference between 190 and 195 is that the 195 have a taller port on them.
The 190 will work the best with your TPI intake but you have to look ahead. Are you always going to keep the TPI? That is the mistake I made. I ended up switching later on to a different intake and now Im wishing that I had a taller port head.
If you are satisfied with the TPI then get the 190's.
-86 IROC
a few mods
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
Old Apr 25, 2001 | 02:51 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I went with the AFR 195 but then I'm currently buildning a 383...
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a AFR 195 headed 383 in the works!! ready May 2001...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
88SS6SPEED
Nov 11, 2015 07:05 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
ULTM8Z
Oct 2, 2015 01:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
buckshot63
Sep 10, 2015 09:15 AM
