idle problem for all u geniuses
Old Apr 25, 2001 | 07:03 AM
purpleworm's Avatar
91 305 tpi auto
My car won't come down off 1550RPM's when in neutral or park. Last year I replaced the IAC and the timing module. The wierd thing about the prob is if I give the gas a couple sharp blasts it will sometimes idle down to where it is supposed to be. This leads me to think that it is the IAC again.
I don't think it is the TPS because the car is working great other than the idle prob. I think the IAC may be binding or something to that effect!! What do you guys think. The more answers the better. You wouldn't know a part# for it?
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit
One sweet sounding system
Old Apr 25, 2001 | 07:48 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Have you checked to make sure that the throttle plates are fully closing and not binding? Next time the idle is high pop the hood and try to manually close the throttle all the way to see if it is actually fully closed. I had the same problem and I just added a helper spring to close the throttle all the way, it works great now.
Old Apr 25, 2001 | 08:26 AM
purpleworm's Avatar
Nope nothing is binding. Everthing is perfect. You can push on the linkage and it is against the stop.
91 Z28 Camaro
305 TPI
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
