biggest cam...
Old Nov 6, 2007 | 07:45 PM
79 trans am's Avatar
biggest cam...
whats a fairly nice camshaft i could run in my stock 305....i have a set of vortec heads with matching tpi base.....im going too push my little motor too the limits before the 400 goes in....
whats the max duration and lift...it will be injected
Old Nov 6, 2007 | 08:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: biggest cam...
Anything with 210 or less duration, .470 or less lift, and 112 or more LSA. And you're going to want to change those springs to handle more lift.
If you can do your own custom chips, you could go with more duration, but I wouldnt recommend it for a 305.
Old Nov 7, 2007 | 01:28 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: biggest cam...
cran compucam 2032, i just ordered mine. should work well with my mods, and a new built tranny with 2400 stall.
Old Nov 8, 2007 | 07:05 PM
Re: biggest cam...
so thanks too kevin91z i can go up too .525 lift and be okay, whats about the max duration????
Old Nov 8, 2007 | 11:03 PM
Kevin91Z's Avatar
Re: biggest cam...
If you change the springs away from the stock ones yes, you can go up to .525 lift. I recommend the Manley 22410-16 springs and 23652-16 retainers. I gave my duration recommendation in post #2.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
customblackbird
Oct 1, 2015 04:30 PM
thekurlyone
Sep 30, 2015 12:54 PM
dbrochard
Sep 25, 2015 04:56 PM
L0tuS
Sep 4, 2015 11:16 PM
