Attn. TRAXTON
Old Apr 25, 2001 | 03:06 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Attn. TRAXTON
I am running my flowmached 22 lbhr injectors on my Mini-Ram motor (see sig. bellow) and was wondering what you thought for my next size of injectors? I was thinking 24 or 30 lbhr injectors. Or do you think Ill be ok for now with what I have?
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel box & coil, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.23 rear gears, white face gagues, and NOS!
Old Apr 25, 2001 | 03:40 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
At the very least ... SVO 24lb injectors (which are really 26lb/hr injectors according to GM standards). With the SVO 24's I was getting around a 90% Duty Cycle at 6500RPMs. I swapped to 30's and got around 77% Duty Cycles at 6500RPMs. Either injector will work fine ... the 30s are better from a DC standpoint and will give you room for future modifications. However, neither of these choices will work well (especially the 30s!!!!) unless you have a chip that matches (IMHO).
I run 30s and they idle exactly like my stock 22's did. But, I program my own PROMs and did the necessary changes to allow this.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Apr 25, 2001 | 03:42 PM
TRAXION's Avatar
BTW ... its TRAXION (pronounced 'traction')
... 'I' not 'T'
Tim
Old Apr 25, 2001 | 04:35 PM
Guido's Avatar
Car: 2000 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
... 'I' not 'T'
Tim
</font>
Smart *** !
Old Apr 26, 2001 | 12:31 AM
Randy92Z's Avatar
Engine: Miniram 383
Thanks for the reply TRAXION. I guess Ill get 30#. I figure running SVO 24# at 90% all the time cant be good. And yea, Ill get the chip done.
Old Apr 26, 2001 | 09:28 AM
TRAXION's Avatar
<font face="Verdana, Arial" size="2">I figure running SVO 24# at 90% all the time cant be good</font>
You wouldn't be running them that way ALL the time. Only at 6500rpms. That's why I indicated that the 24lb SVOs would be fine
Tim
Old Apr 26, 2001 | 03:46 PM
Randy92Z's Avatar
Engine: Miniram 383
Oh, my bad
gp90gta
Aug 1, 2016 07:32 PM
92GTA
Sep 7, 2002 12:06 AM
blowen90ta
Jan 20, 2001 12:01 AM
