Help me make more power!!
Subscribe
Apr 26, 2001 | 11:21 PM
Hi guys,
Time for everyone to put on their thinking caps here. You'll all call me crazy but I'm going to ask anyway. My IROC has 140,000 miles on it, stock 350TPI....I wanna up the ponies in it without doing alot of work...Saving that for when I actually tear the engine out of it. Anyway, can I put a cam in it without removing the engine as long as I take the radiator and AC condensor out? I'm removing the nose to repaint it anyway so that part is not an issue....Basically I'm asking what minor things I can do to give it a little more spunk. Thanks for any help you can give.
Reply 0
Apr 27, 2001 | 03:42 AM
changing cam is trivial task. prepare to take off quite a lot things before you can access the cam. at least induction, waterpump, damper, valve covers, etc.
change cam chain once you swap the cam. and don't put too much cam. if i'd be you, i'd choose ZZ3/ZZ4 cam. specs of it looks nice and mild enuf for stock engine
p
Reply 0
Apr 27, 2001 | 05:20 AM
Check out this article:
http://www.racer-x.f2s.com/proc/caminst.htm
He lays out everthing you need to do!
Hope it helped.
Good Luck!
Reply 0
Subscribe
