10 second TPI
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
10 second TPI
Is it possible to get an L98 TPI down into the 10 second range without Stealthram/Miniram/Superram and without upping the dis?
Basically, can a 3rd gen f-body make it to 10 seconds on a 350 LTR TPI setup?
Thanks in advance for the insight
-Tim-
-Tim-
Re: 10 second TPI
. . .dude
Hi I'm a reasonably new person/poster here on tgo, and could not let this one get by me. Yes you can make an ltr set up go 10's, but there is a necessary turbocharger set up in the mix.
There is a guy on the turbomustang site which did this on a jy longblock while his 'special race motor' was being prepared. He called this special project the 'grenade', fully expecting to blow the thing all over the track at some time. But the did it right, great tune, fuel and spark in the proper places at the proper time, good suspension-not great suspension and a couple of needing to be rebuilt GN turbos.
I think the final result was that he was in the 9's (mid-hi) at pushing a buck forty-ish.
Most of the readers were anticipating that he would pop the thing, and most expectged that it would. With a good tune, surprisingly , it held. Hi mile jy longblock, not even 1.94 valves, ltr tpi, and I believe amazingly stock.
His psi was around 20, and with a 50 shot it was around 25, and I believe his timing was around 20*.
So t answer your Q about 10 sec. et's, my answer is yes, this is just one way to do it, and with cast pistons no less. Just a great tune. If you can find the thread, it has to be one of the greatest on the internet for our hobby, more laughs than I can remember, and no blown engine.
Have a great day
Bill
Have a great day
Bill
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 10 second TPI
Anything is possible. Even with a true "TPI" it's possible. How much money do you have?
I've had people here tell me that you can't get 500 fwhp out of a "TPI" without forced induction or juice. I'm gonna prove 'em wrong. All I have left to do is tuning.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 10 second TPI
i would say it would be possible in a gutted out race car if its gonna be n/a
you can siamese the TPI and make it more short runner but then its not a "TRUE" LTR setup but still could be possible.
Guy on here has made 350whp with a siamesed setup on a 355. cam was fairly small tho. could go up a step and probly get up to 370whp. combine that with a ultra light car and you may crack 10's LOL
but other than that its gonna take forced induction or nitrous
its probly gonna take 420-450whp to touch 10's in the right car
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 10 second TPI
Hey Viprklr I will be on the dyno by December so you need to get a move on if you are going to be first.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 10 second TPI
Its gonna take way more than 420 horse to get into the 10's. I am making 470 and can barely get into the 11's. To get into the 10's with a pretty stock TPI your gonna need forged internals, a turbo or supercharger, and or a 200 shot of the juice. I have heard a guy in the high 9's with something like that. But if you were to do all that you would spend a lot that being both the motor and the chassis, cooling system.
Car: 89 Iroc-z
Transmission: TH400
Re: 10 second TPI
i was talkin about 420 at the wheels which is probly near 500 on motor and for that power it will take a lightweight car with perfect suspension/converter combo to squeak 10's
Car: 92 GTA/ 00 TA
Engine: 383/350
Car: 89 Iroc-z
Transmission: TH400
Re: 10 second TPI
500 Fhp will be very interesting to see. should dyno very high 300s to low 400's depending on trans etc. that will be a stout TPI. i thought it could be done on a big 383-406 or something but never on a 355
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 10 second TPI
Originally Posted by Imadude_134
Is it possible to get an L98 TPI down into the 10 second range without Stealthram/Miniram/Superram and without upping the dis? Basically, can a 3rd gen f-body make it to 10 seconds on a 350 LTR TPI setup...?
As for 500-FWHP with the stock TPI system, naturally aspirated... it'll be tough to do, but with a power adder, you'll easily hit that mark. Good luck!
Car: 1989 GTA
Engine: 369 TPI
Re: 10 second TPI
Viprklr, yes it is basically all done. Working on the monoblade right now to make it "smog legal" so to speak. Going to see how close I can come to 500hp at the motor. As to a 10 second car maybe with a 100 to a 150 shot I might be able to do it.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: 10 second TPI
Hahaha. I'm a college kid and I realized that buyin a miniram and doin other stuff is easier and cheaper than doin a TPI. But i always wanted to do it. I know an article in Chevy Hiperformance that did a TPI 383 like almost 500 hp and 500tq.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: 10 second TPI
for the guys on this thread that are lookin to hit 500fhp what are you runnin fr a cam/heads.....will it pass emmission? i also would like to build as much power as i can from a LTR setup. juts need to find the right cam that will pass.
Car: 89 Iroc-z
Transmission: TH400
Re: 10 second TPI
my thoughts on a LTR setup for 500 fly wheel hp are big inches, best heads money can buy and a cam that will have massive lift.
something i'd like to see is a 406+ inch chevy with ported 195-200cc heads that flow near 280-300cfm if possible at 600 lift and a cam that gets lift near that high. Something like an XFI 230-236 with near 580 intake lift. that should act good in a big inch TPI motor. Could possibly go 236/242 custom XFI as well but i think that would rev to much for a LTR. for LTR it have to be the biggest ported runners you can get with a matched base. extrude honed, maybe even a welded up base so you can open up the pinch point on TPI bases right where it goes into the runners/heads. You have to flow a theoretical 245 cfm to support 500hp but we all know theory is under estimating the reality. its probly gonna take a good 260cfm atleast probly more. not sure i've seen many TPI setups if any at all flow that much. I believe the welded up intakes can flow pretty good tho.
the HSR flows 275cfm and is said to max out near 400whp on most applications. TPI I dont think has the potential to make much more power than that on a BIG inch motor.
I'd love to see a 383 do it tho. i just have my doubts since TPI cant support the RPMS needed to make that power as a miniram/hsr can.
and i dont think it would pass emissions tho
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: 10 second TPI
My combo, as of yet untested, consists of:
Stock TB for now
AS&M runners gasket matched
Bigmouth base gasket matched
AFR 195 Eliminators
Comp XFI custom 224/230 .566/.570 112 incl 1.6rr
All sitting on/in a 383 now. Melted a piston in my 350.
DD2K puts me at 534hp/540lbft at a peak horse value of 6K. (which I can spin). Just need to tune more before going to the dyno for the hard proof.
Stock TB for now
AFR 195 Eliminators
Car: 89 Iroc-z
Transmission: TH400
Re: 10 second TPI
i cant wait to see how that combo runs.. i think its good enough for 500 crank if the intake is good, like an hsr or miniram. then again teh cam is abit smaller than i'd go. 280xfi would be nice to see. will a tpi feed it? hard to say, i think you will be a bit short
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: 10 second TPI
What would be possible to hit 11s with LTRs NA without nitrous?
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: 10 second TPI
Same deal with my headers. 1 5/8 LT's. I should be running 1 3/4. At least I have other avenues to pursue in the future.
Car: 89 Iroc-z
Transmission: TH400
Re: 10 second TPI
yep there is some hp in those two areas. i'd love to see how that cam runs, i'd love to run that on my 350 HSR but i'm worried about the mileage of the motor. may need a rebuild first
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: 10 second TPI
It's got a bit of a lope.
The cam seems to be running quite nicely. Acceleration from 80-135 is the same as if I was accelerating from 40-80. No noticeable dropoff. Haven't seen the need to go over 135. Country driving has it's benefits.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Sanjay
Aug 12, 2015 03:41 PM
