What mods do I have to do to install an LT1 intake on older engine.
Old Apr 29, 2001 | 02:00 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
At present I have a 91 Vette TPI installed on my 1972 LT1 Corvette. I have a chance to buy a 1993 LT1 intake. Other than the center hole mods, how can I do this? Water jacket flow, distributor mounting, ETC. ETC.?
1972 Corvette LT1
Keith Black 9.7:1 Pistons
Comp Cams 480/480 lift @220 Duration
Original 4 Bolt Steel Crank
1.5 Roller Tip Rockers
336 Posi Rear Chunk
1991 Speed Density TPI setup
DUI Special order Tachdrive Distributor
Old Apr 29, 2001 | 04:15 AM
88CK/L98's Avatar
The newer Lt1 manifold will not fit the L98.The Lt1 uses opti spark the L98 uses distributer.The Lt1 uses reverse cooling the L98 uses conventional cooling.There are also differences in the angles of the heads and the block as well as port alignment differences between the two.I hate to be the bearer of bad news,but that is why the Lt1 manifolds are so cheap when bought used.They just don't interchage with the older sb chevys.
Old Apr 29, 2001 | 01:55 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I like a challenge ...
I am making the assumption that the intake, heads and block will line up. If they do ...
You will need a distributorless ignition, something with a crank trigger. There is limited room to mount dist. back there.
The next is the water passage. You will need fab up some mounting to allow coolant to flow, so perhaps AN fittings threaded into the intake might solve that. There is not much room for large fitting, so flow might be a problem. I am not sure how the thermostat would fit into the system.
If you knew someone good with an aluminum welder, you should be able to do something with it. But when you add up the cost, a miniram II might be a better choice.
Mark.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
