Please help car dies when warms up
Old Nov 12, 2007 | 01:06 AM
83Formula's Avatar
Ok i have a 91 Firebird TPI 305 LB9 with an "F" engine code 5 speed, i can start the car and drive it (or let it idol) till it warms up then as soon as it warms up it dies and will not start, it will turn over but not start, some times it'll start (1 in 5 trys) it'll idol (kinda) but as soon as i give it gas it dies again. i checked the fuel pressure it tests at 42 lbs (normal i think), i checked the spark and it has spark too, i really need help.
i replaced the fuel filter and the map sensor too but it didn't fix any thing (don't know if that matters).
Thank you
Old Nov 17, 2007 | 11:33 AM
frirebird952's Avatar
Car: 86 ta ws6 silver and gun metal
Engine: 305 fi lb9 eng code f
Transmission: 700 r4 with shift kit
Axle/Gears: lim slip not sure gears
Re: Please help car dies when warms up
it can only be fire or fuel . you checked the fire was it hot enough or was it week i have seen the control module go bad and will run till they get hot then eng shut down and with week fire it not run the coil can also do this but not as common hope i helped you if its not fire or fuel it would have me at wits end 2 good luck
Old Nov 17, 2007 | 11:42 AM
dethklok81's Avatar
Car: '88 Trans Am
Engine: 5.0 LB9 305 TPI
happened to me last month..
last run before storage.. on my way home (stored it 7 hrs away)...
i died in rush hour toronto... my ignition module died on me...
once i replaced that... it runs awesome again...
so i kept it out of storage a few extra days then!
Old Nov 18, 2007 | 10:13 PM
83Formula's Avatar
Originally Posted by frirebird952
it can only be fire or fuel . you checked the fire was it hot enough or was it week?
How do you tell if its hot enough or not? i used a light tester you put inbetween the spark plug and wire
Ignition module?
http://www.autozone.com/R,APP37162/v...ductDetail.htm
or spark module?
http://www.autozone.com/R,APP532966/...ductDetail.htm
Thanks i'll try that.
Well as of right now i haven't changed any thing besides cleaning the ground and trying a new ECM but the car still dies when it warms up i can restart it and it idles ok but when i try to rev it up it only boggs really bad make a little hollow pop noise from the engine and if i dont let go of the gas it dies completly. can not drive the car at all when it warms up but runs like a champ when you first start it cold in the morning.
i'm going to try the above ideas as soon as i can.
Any sudgestions with that update? thanks again
Old Nov 19, 2007 | 12:42 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
pull the injector terminals off one at a time and try to start it
if one of the injectors is going bad it will ground them all
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
