350 vs supercharged 305
Old Nov 12, 2007 | 10:18 PM
racerx520's Avatar
i am the proud owner of a 1987 trans am....it is a 305 tpi with 144,000 miles on it, but i can probably gut most of the motor and freshen it up and throw a supercharger on it or....
buy a 350 long block from the junkyard and build it up and maybe add some extra parts to add some power in my basement and then throw it in maybe next summer....
what do you guys think?
-brian
p.s. this is my daily driver
Old Nov 12, 2007 | 10:25 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
Re: 350 vs supercharged 305
supercharging an old 305 may not be the best idea but I would personalyl go with the save some money and do it right the first time choice. jsut my two cents. but it you were to do one or the other I would go with rebuild the 305 bigger crank and heads then add all new internals and then the supercharger. I still just say do it right the first time.
Old Nov 13, 2007 | 06:01 AM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
take your 305, get splayed caps, put a low compression rotating assembly in there, put a supercharger on top.
Old Nov 13, 2007 | 09:09 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
procharge it dude!!! i am
Jake_92RS
Jan 28, 2020 10:37 PM
toronto formula
Nov 10, 2015 06:17 AM
Dwayne614
Sep 28, 2015 08:33 AM
PestilenceIV
Aug 20, 2015 03:32 PM
st.evel07
Aug 13, 2015 06:15 PM
