Can You Reuse TPI Runner Gaskets?
Old Apr 30, 2001 | 12:11 PM
Jas89TTA's Avatar
Can I reuse my TPI runner gaskets after I installed them. It was only on the car for less than 20 miles and I had to pull the fuel rail off? They look fine it's just they are TPIS gaskets and I don't have a extra set lying around.
Old Apr 30, 2001 | 12:17 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
I've reused mine twice and I've had no problems.... there were a lot more than 20 miles between disassembly between them too... you should do ok as long as they aren't torn.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old May 1, 2001 | 02:34 AM
age's Avatar
age
Car: 1992 Z28 1LE
I'll second that on reusing gaskets.
Old May 1, 2001 | 07:00 AM
90 Z28SS's Avatar
I re-use mine all the time . Especially on Mass Air cars pay real close attention for leaks . If fresh air is gets in the intake tract without being metered by the MAF your computer will run the car rich .
Derek 90 IROC 5.7
Mods: All the usual bolt ons siamesed base , 2500 stall , 373's , SS hood ,big and littles , lotta reduced weight. Stock heads/rockers , cam ,runners , chip and TB
Best Et: 13.12@101 ...1.701 60 ft.
Old May 1, 2001 | 12:56 PM
Jas89TTA's Avatar
Thanks.
Old May 1, 2001 | 01:19 PM
Synergy's Avatar
I've reused mine a couple of time and sure enough they leaked. There was probably about 2000 miles in between changes. If they're very dark and very flat already, they're probably going to leak.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old May 1, 2001 | 07:26 PM
Guest
Guest
Posts: n/a
Ive reused them but try to avoid it. If they are fairly new, its not usually a problem unless they are damaged. Older ones that are missing material or flat like stated above are usually prone to leaking.
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
qz6lwp
Aug 20, 2015 08:10 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
