TPI on 1965 327 motor?
Car: 1985 Chevrolet Camaro IROC
I was talking to a friend of mine who is considering putting TPI on his 1965 327. He doesn't have the internet, so I will be doing the asking. He doesn't know if he will be going with the earlier or later style TPI, but we will save that for a later post. Has anyone done this before or does anyone have any information on this setup. This should be going into an 86 IROC shortly!!
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
Rob Kowalski
That does not sound like a good matchup....A 327 is a high-rev application, where TPI is for low revving torque applications. As much as I like TPI, I would not put it on a 327.
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
Engine: 5.7
I agree bad combo. The 327 is a high RPM engine and a stock TPI (made for low RPM torque) starts crapping out above 4500 RPM. With fuel injection it's all about combination. I think your friend will be disappointed.
87 Iroc 5.7, AFR190, SLP Cam(218/224), SLP 1 5/8 headers & cat back, Random CAT, SLP Runners, 48mm TB, custom chip(by me), Vigilante & Probuilt trans.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
yeah bad combo total mismatch...one would cancel out the other...a 327 LOVES to rev...the TPI would stop that quick...and vice versa...a TPI makes great low end torque..where has a 327 makes a lot of power top end
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
if ya wanna go fuel injected, get teh computer, wiring harness, and injectors from a tpi car and run a mini ram intake. this is kinda like an LT1. that would be a great combo! a high revvin 327 with a mini ram would be a match made in heaven.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
P-E-R-F-E-C-T for a 327. The bare intake is $255 from summit, get a TBI to carb adapter, put a 454 TBI on it minus injectors and go to town
. See if you can use TPI fuel rails, if not you need to get some from holley. www.holley.com------------------
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited May 01, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
