propane powered LT-1 ???
Old May 1, 2001 | 05:27 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
a local used car dealer is selling an ex-cop car, that is powered by a LP-V8, I've not heard of a liquid propane fueled V8 for chevys.It is a 94' caprice (sorry if I spelled it wrong). the guy was too busy to show me what was under the hood. I think those cars were equipted with LT-1 and some with LT-4 ,not sure. Does anybody know about this engine?
Old May 1, 2001 | 08:02 PM
Tas's Avatar
Tas
The only propane run cars I've heard of used special carbs. I've never heard of an EFI one. Propane stinks like hell though. We have a propane forklift at work and its aweful to be around.
As for the cop car: LT-1 is the engine from the early 70s. The LT1 is the modern version. There was no LT4 offered in the Caprieces but it would be a virtual bolt in for a LT1. The LT1 in the cop car had iron heads(unlike the F-body and vette version) and was believed to flow better than the aluminum versions. They were rated at 260HP in these cars.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 1, 2001 | 08:20 PM
F22Raptor's Avatar
<font face="Verdana, Arial" size="2"> The only propane run cars I've heard of used special carbs. I've never heard of an EFI one. Propane stinks like hell though. We have a propane forklift at work and its aweful to be around </font>
Well, I know for sure there are cars with EFI running propane, butane or one of them funky gases. I know the Air Force has a bunch of cars, pick ups and even tractors running gas.
I also heard that it kills power on tractors. I have personaly driven 1/4 and 1/2 ton pick ups and didn't notice the thing run like a dog. It might have been down in power, but it wasn't like driving a 350 and then getting into a honda civic.
Rick
Old May 1, 2001 | 08:24 PM
Tas's Avatar
Tas
the octane is crazy on propane though, they might not have been set up to use it. i.e. compression ratio like 8.0:1 truck using 112 octane propane. UIt could probably take having 13:1 or something crazy like that. I saw a big block chevelle on TV running crazy compression because of the propane.
Old May 1, 2001 | 09:02 PM
Vader's Avatar
91,
The Caprice SEO vehicles in '94 all had LT1 or L99 engines. There was no generally available LT4 in a '94 Caprice.
There are eleventy-jillion Vortec engines arounf the world running on LP and LNG. They require a regulator, and evaporator, and special carburetor or fuel distibution. Propane burns much more cleanly and cooler than gasoline, and propane engines tend to last a lot longer than their gasoline counterparts.
F22 is correct - VERY correct. There are several shėtloads of government vehicles using millions of cubic feet of propane every day, from the armed services to the postal service. There is a little less power output from LPG at a given displacement and compression, but an engine built expressly for LPG can be built with a lot more cam timing and static compression, so the power levels can be the same with a little planning.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
