Attn: TFS 23* Head Owners: Sprak Plug Question within !!!
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I read over the sheet that comes with the heads and it says to use, among others, FR3LS A/C plugs. Are any of you using these? If not, what kind of plugs are you guys running?
Thanks in advance,
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Thanks in advance,
Matt
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Im running the new urideum (sp) plugs from Bosch. I dont have the part # though. The parts store cross referenced them for me. They seem to work great!
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.23 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
I'm using those plugs in my TFS 23 heads. I gapped at around 60 and they work pretty darn good.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
92 Z28 5.7
evilstuie
Feb 28, 2016 03:33 PM
