fpr, intake manifold and plenum questions
Old May 2, 2001 | 12:05 PM
lb9formula91's Avatar
where is the fpr located and how hard is it to change, how hard is it to port the intake manifold and can it be done with a dremmel and how and how hard is it to port the walls inside the plenum. Also whats the stock fuel pressure for a 91 305 thanks for the help
91 formula
305 tpi
borla exhaust
white face gauges
home made cold air
tpis airfoil
Old May 2, 2001 | 01:08 PM
rondubbs's Avatar
welcome aboard..
the fpr is located under the back left side of the plenum, its a small black thing.
to change it you need to take off the plenum and use a special torx security bit to get the fpr off.
porting the plenum is real easy, http://www.tribal-treasures.com/cars...-port/port.htm
dont know about the intake
the stock fuel pressure is between 41-46 psi, you need to check it with a fp gauge to see what yours is
Old May 2, 2001 | 01:47 PM
thanks this will be greatly appreiciated thanks again
Old May 2, 2001 | 02:26 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Or if you're a lazy SOB you can get the FPR screws out by grabbing the heads with vice grips and turning. Take s alittle longer, but at least that saves you the oddyssey of tracking down a security torx driver (Last time i asked where the regular torx stuff was at sears i had 2 people point me in the wrong direction, i could just see me trying to explain the difference and trying to get them to find it in a catalog for me.)
As for porting the plenum with a dremel, thats all i used. Just a high speed cutting bit for 98.5% of it, then a little smoothing touch up work with a stone.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
