TPI Swap - MAF to SD
Old Nov 13, 2007 | 09:30 PM
hzemall's Avatar
This is my first post here, I was told you guys were the authority on this topic so I figured I should get the help from the experts.
I have a 1986 Buick Regal. It came with a computerized Carb V6 in it.
I have a pre 87 Chevy 350/375HP crate motor for it. I just recently bought a 1985 TPI setup off eBay for it (plenum, intake, runners, fuel rail and throttle body). I was told this will bolt onto my old style heads.
I want to run this as a SD setup instead of the MAF. What all has to be done to so this ?
Also, when I order all the new sensors etc do I order them from a 90/91 Camaro to match up with SD set up and the 90/91 ECM I will get.
Any help you can give would be great.
89GTAOz
May 16, 2020 09:31 AM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
