Could my car be running to.......cool?
Old May 1, 2001 | 12:27 PM
86Trans Am's Avatar
After installing my headers and cat-back, the car rarely gets above 160 degrees while cruising. If i sit in traffic in 80 degree heat it gets a little warmer, but i'm concerned that it is never getting into closed loop. Is this possible?
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old May 1, 2001 | 03:56 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
change your thermostat. get one that is at least 180 degrees.
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
t-56 trans
9" ME rearend
Old May 1, 2001 | 08:06 PM
86Trans Am's Avatar
the stock thermostat is still in it, i believe its 180 or above
1986 Trans Am
305 TPI
Old May 1, 2001 | 08:16 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes, but when was the last time it was changed? They don't last forever. Generally, when they get older they become "weaker" where they don't fully open nor close: something like you are experiencing.
Old May 2, 2001 | 08:28 PM
86Trans Am's Avatar
Ahhh, so your saying it could be stuck open....can i just pick up a thermostat from a parts dealer and specify 180 degrees?
thanks
1986 Trans Am
305 TPI
Old May 2, 2001 | 08:32 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
You can go to a parts store and get a thermo they are not that expensive and get the gasket as well. Total cost will be like $8 or so.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
