Q's on ECM swap: 870 ==> 165
I have a couple question regarding the article at:
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
I know few of the people here have done the swap and know what is exactly involved. Before I start yankin' wires I want to know some more info.
* Do the ALL ECM connectors from the 870 get retained?
* " Relay Harness plugs can be ordered thru a GM dealer under P/N 12101922 for about $25 each. -- Thanks to Kevin Irving for this tip"
what exactly are those plugs? $25 is a lot for just the end fittings for the relays. Or are they the relay harness themself?
* Is anybody able to clearify what they didn't understand in the article before they did it.
It looks pretty simple but it is still intimidating because I know there is the potential for misinterpretation.
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
James
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by james_fearn:
* Do the ALL ECM connectors from the 870 get retained?</font>
<font face="Verdana, Arial" size="2"> * " Relay Harness plugs can be ordered thru a GM dealer under P/N 12101922 for about $25 each. -- Thanks to Kevin Irving for this tip" what exactly are those plugs? $25 is a lot for just the end fittings for the relays. Or are they the relay harness themself?
</font>
</font>
<font face="Verdana, Arial" size="2"> * Is anybody able to clearify what they didn't understand in the article before they did it.</font>
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
[This message has been edited by Kevin Irving (edited May 03, 2001).]
about the P/N 12101922 harness:
the word plug through me off. So that harness and the relays are the only "foreign" parts I need (besides the ECM)?
Do I need a harness for each one (qty 2) or does one harness do it for both relays?
TPIs and harnesses are ripped out before the public can get a whack at them around here. I feel your pain.
Did Mike have to enlarge the hole where the wiring enters the interrior?
Thanks,
James
Thanks,
James
Car: 1985 Trans Am
the word plug through me off. So that harness and the relays are the only "foreign" parts I need (besides the ECM)?</font>
<font face="Verdana, Arial" size="2">Do I need a harness for each one (qty 2) or does one harness do it for both relays? </font>
<font face="Verdana, Arial" size="2">Did Mike have to enlarge the hole where the wiring enters the interrior?</font>
efiguy
Sep 27, 2015 01:30 PM
