13's possible on stock intake/heads????
Old Apr 30, 2001 | 10:06 PM
CamaroX84's Avatar
I am wondering if my car will make it into the 13's in the quarter mile. I have a 1989 350 TPI motor (bored .030" over). I have a gutted air box with two 5 inch ram-air tubes and two K&N filters. I have the stock TPI setup, except I have an adjustable fuel pressure regulator. I have stock reconditioned heads with a radius valve job and new springs. I have a Crane Compucams camshaft (214/220 duration @ .050"). I also have Hooker headers, a high-flow 3 inch cat, and a Hooker cat-back. I have a 700R4 tranny with a TCI Breakaway torque converter, an aluminum driveshaft, and a 3.23 Posi rear. Will this setup with the stock throttle body, plenum, runners, manifold, and heads see at least 13.99 in the quarter mile? Any help/suggestions appreciated. Thanks.
[This message has been edited by CamaroX84 (edited April 30, 2001).]
Old Apr 30, 2001 | 10:32 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
It's a possiblity! A friend of mine has an IROC with a stock 350 in it.... only thing he's changed is the injectors and he put on a 75 shot of NOS! This past Friday he ran it at the track and WITH the 75 shot of NOS he ran a 14.1!!
Old Apr 30, 2001 | 10:52 PM
CanadianBeast's Avatar
I think your there. My car has run low 14s (14.2-14.4) at 99-100 mph, I had horrible traction which led to the relative high et's compared to mph. This is on a 89 iroc L98 with k&n's, airfoil, removed plenuum walls, afpr, shiftkit, 3.42's, removed maf screens, cat back exhaust, removed CAT. I'm pretty sure that it will run a high 13 with some sticky tires.
Since then I've installed slp headers, underdrive pullies, removed AIR system, and I'm in the process of burning a ARAP based prom.
Your car seems fairly comparable to mine but you have the cam and torque converter which should make it noticebly faster than mine. If you can hook up I'm pretty sure youll run a 13.
Old Apr 30, 2001 | 10:58 PM
DON 88T/A's Avatar
If the car is tuned,and you can hook a little...yeah easily.
What is your fuel pressure at?
Timing?
What is your stall?
Port that plenum(very easy) pull screens on mass air,....attacking the intake as a whole gives best results....a cold air setup helps too/along with foil...any one ofthese intake mods by themselves net very little..but all of them combined is where the gains is at.....work on your launch..if you can get that car off the line fairly strong,you'll be runnng good.
Old May 1, 2001 | 01:18 AM
90 Z28SS's Avatar
Check my sig , its definately possible . Play with the timing and fuel pressure at the track . My timing ended up best at 12* initial . Generally 8-10* works best for the TPI cars though .
You ever go to US 41 dragway?
Derek 90 IROC 5.7
Mods: All the usual bolt ons siamesed base , 2500 stall , 373's , SS hood ,big and littles , lotta reduced weight. Stock heads/rockers , cam ,runners , chip and TB
Best Et: 13.12@101 ...1.701 60 ft.
Old May 1, 2001 | 06:54 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
if u can hook u might be there already...what is the stall speed on your converter?
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old May 1, 2001 | 11:03 AM
formul8!!'s Avatar
Car: 2004 GTO
If my '89 Formula 350 with a slipping trans,timing outta whack,a crappy 60ft times can run a 14.20@99, then your can run a 13.XX if you have it tuned properly and get it to hook off the line. I also have a Edelbrock intake, SLP exhaust,etc.
Old May 1, 2001 | 11:42 AM
IrocStan's Avatar
I've done it.
I pocket ported the 083 casting heads, and ported the plenum. Stock cam/valvetrain, base, runners, chip, trans, stall, and crappy radials. Check out my web page for more details.
I don't think that you will have any trouble doing it.
87 IROC 350
13.94@103mph
Check out my new web page.
http://austinsiroc.homestead.com/Home1.html
Old May 1, 2001 | 07:51 PM
JERRYWHO's Avatar
Spray all the way and you can go 12.50 or faster with a factory stock L98 thats never had the intake or valve covers off see my sig.
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EIBACH spring kit, NITTO'S, N.O.S.
best 60ft 1.84 1/4 12.48 @ 110.81
Old May 1, 2001 | 08:38 PM
CamaroX84's Avatar
My stall speed is about 2000-2200 RPM. I'm not sure what I'm going to set the fuel pressure at. I was thinking 48 PSI or so. I do not plan on running nitrous oxide either. Thanks for all the replies.
Old May 1, 2001 | 09:45 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, u can do it N/A!!
[This message has been edited by IROCZTWENTYGR8 (edited May 01, 2001).]
Old May 2, 2001 | 11:53 AM
Kyle F's Avatar
I did it on a 355 with an SLP cam mild upper intake porting, 305 heads, and a good 700r4 on 2.77 gears. pulled a 13.9
I had all kinds of other stuff done like removing th A/C, fibeglass hood, Headers, Flowmasters, all the free stuff, bumped up the fuel pressure, larger Throttle Body. and so on. If I would have had a set of Vortec 350 heads and a 3.42 rear I would say I could have pulled a 13.5 easily. My gear hurt my car so BAD it wasn't funny.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old May 2, 2001 | 05:59 PM
87iroczmd's Avatar
i put a th 350 in with 3200 stall, i can run low 13's all day with stock heads, cam, intake, i have headers, a chip, a thermostat, and some bolt ons, my friend has an 87 355 stock rebuild with hardly a few of the free mods and a chip and runs 13.9's, some people's cars don't seem to be running right to run 14's, maybe it's the fact that some 700 r4's leave you stuck in third when you are full throttle and you run out of power
Old May 7, 2001 | 07:59 PM
black5.7GTA's Avatar
13's You can hit high 12's in a tuned L98 F-body,with stock cam/heads with a converter,3.54's,Exhaust,SR's,ported intake,and TRACTION!
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,
SLP Package,SLP Torque Converter/Shift Kit,Fastchip,GSC's
G-tech 0-60 5.1 1/4mile 13.6@104
member www.transamgta.com
Previous Thirdgen
1986 Camaro IROC-Z
Old May 7, 2001 | 08:20 PM
BadBowtie88's Avatar
High 12's...I don't know about that. Only if it is done right. If you have everything suspension: lowering springs, upper and lower control arms, so forth and so on. But, as far as mid to low 13's, definitely.
1988 Iroc-Z
L98 350 TPI
700R4 Tranny
2.77 gears(will change)
Mods: Crane CompuCam, headers, gutted air boxes
Best e.t.: 14.49@95.5mph
60ft.@2.27(was 2.12 w/o cam)
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
