fuel pump?
Old May 8, 2001 | 11:56 AM
Reno's Avatar
fuel pump?
OK, I know this is beat to death a lot. Here's the details though: sometimes when I start it, it will do the whine in the back, so I know it's pucshing fuel, and after a second or two, it'll stop. Sometimes it won't though. Should it ALWAYS spin up, or not?
-Rick
89 Formula
Old May 8, 2001 | 12:14 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It depends on how cold the coolant is. If the engine's cold and you "prime" the pump, it'll prime for 4-5 seconds, if the engine's warm or hot, it'll only prime for 1-2 seconds. If you've just primed it or just shut off the engine, it won't prime again for something like 30 seconds. If it's been more than 30 seconds and it isn't priming, then there's something wrong, probably an electrical problem. However, if your engine is starting up OK, then I wouldn't worry about it until your fuel pump starts dying.
Greg Westphal
'87 IROC 305TPI/A4
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
