TPI Stalling out
Car: 1991 RS Hardtop
Axle/Gears: 3:23
TPI Stalling out
I receintly did a motor swap in my 91 RS. The TPI motor was running great and I was driving the car. However, a few days ago I went out to start the car, it cranked, fired, and stalled. If I give the car very little gas, it stays running, until i let off the throttle. When I'm giving it throttle, it runs smooth and sounds great. I assume its a VERY minor problem becasue the motor sounds great. Has anyone had or heard of this before? Any help would be great!!
The motor is a 1988 rebuilt 305 TPI put into a 1991 RS original V6 car with a 1991 Z28 Speed Density Wiring harness.
Axle/Gears: 3:23
Re: TPI Stalling out
Thanks, I'll be working on the car tomorrow night, i'll definatly check that. is there a posibility that it could be a gas problem? I know the sending unit on the fuel pump is busted becasue my gauge doesn't work, is it possible its not sending enough fuel on start up but when i give it throttle it can pull more? I'll be using a fuel pressure gauge as well tomorrow night, but just trying to trouble shoot so i know where to begin. Thanks!
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
same thing happened when i bought my car ..
i took off the throttle body and a couple cans of brake cleaner later .. and a new tps and iac .. and presto .. it purs like a tiger (not a cat ... there too *****) ... lol ... oh .. and a new fuel filter .. mine was clooooogged .. suprised it even ran ..
neways .. try that .. if not ive seen somewhere about a fuel pump relay .. idk ..
Axle/Gears: 3:23
Okay, I just checked the fuel pressure, and its good. Its definatly an air problem at start up. I checked the IAC and cleaned it thinking that was the problem, but the cleaning didn't help. It might be busted, i have to test it. I also played with the TPS and it didn't seem to make any difference, the car purs like a tiger as soon as i give it throttle still, but when i let off, its dead in under a second.
Sanjay
Aug 12, 2015 03:41 PM
