mini ram am i ready for it?
Old May 8, 2001 | 03:54 PM
bad camaro RS's Avatar
im done with trying to make power from tpi you think my current combo is ready for a mini ram to be installed you think ill notice much of a gain? is tpis only place to get one? combo is compucam 2032 w 214-220 dur 495 510 lift gutted maf mas 6al 10-1 compression custom ed wright chip afr 195cc heads with compition port work 1 3/4 hooker l/t 4" mufflex system thanks
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old May 8, 2001 | 09:56 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
IMO, you'll need a bigger cam to take advantage of the miniramm high flow heads and exhaust...something like a Comp Cams 305 or 306 cam. Basically the same cam the LT1 guys use. I assume you have an auto...get a 3000-3400 PI or Yank converter and 3.73s. The rest of your motor is "miniram ready"...it begs for a big cam. Then you'll need to reburn your prom for the bigger cam.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old May 8, 2001 | 10:02 PM
ive got 373 afr 195cc with compition port work 1 3/4 long tube headers 4" mufflex system so cam and mini ram should really wake me up ???
4" mufflex system
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
09ave
Sep 7, 2015 06:03 PM
