Is this a problem: 88 large tube runners on 89?
Car: 89 IROC
Engine: vortec head/ZZ4 cam/TPIed 350+.040
Axle/Gears: 3:27
Guys, I just purchased a great set of used ASM large tubes off an 88 corvette. However I have an 89 IROC. I know I can plug the CSI hole in the runners. But there is a CSI tube that runs up to the Plenum. When bolted to my 89 Plenum, the tube is open to the outside air because the 89 plenum is missing the additional casting for the CSI.
Is this a problem?
Is this a problem?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Is this a problem: 88 large tube runners on 89?
Yes, a huge vacuum leak like that is a problem. You need to seal that entire CSI tube.
Car: 89 IROC
Axle/Gears: 3:27
I figured but, was not sure how the CSI air flow worked. I guess plugging the hole or getting a plenum from an 88 are my choices.
88SS6SPEED
Nov 11, 2015 07:05 AM
Chas91Z28
Oct 22, 2015 10:12 AM
toronto formula
Sep 10, 2015 07:31 AM
