headers and knock sensor
Old May 12, 2001 | 01:35 PM
racer101's Avatar
when i put the headers on and first started the car the paint burnt off and they turned white with ash, there is one tube that after
having run it a dozen times has not yet turned white. is the cylinder not firing or is the injector clogged?
also where is the knock sensor located?
Old May 12, 2001 | 02:25 PM
Vader's Avatar
101,
It sounds like you have an ignition, compression, or fuel delivery problem on a cylinder.
The detonation (knock) sensor is located on the right side of the cylinder case, down low along the oil pan mounting rail.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
