Fuel pump problems
Old May 4, 2001 | 06:14 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Fuel pump problems
In the past 8 weeks the fuel pump has lost fuel pressure 5times when the coolant temp reaches 220degrees which is when I'm stuck in traffic.I drove it from Pa to S.I. a week or 2 ago w/o a problem.As long as it doesn't get hot works great.Replaced fuel pump number of times and fuel filter.Couldn't find any kinks in fuel line.would the fuel pump relay act up when hot?Anybody else have this problem.
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,Dan Burk ported intake system,,March
pulleys,Accel 8.8wires,ign.mod,Crane PS-91 coil,Crane HI-6S ign.box
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod,mac subframe connectors.polygraphite bushings
"The more I learn about women,the more
time & money I spend on my IROC"
Old May 10, 2001 | 06:04 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
ttt
Old May 10, 2001 | 06:55 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
How do you know it is losing pressure, do you have a guage on it? It sounds like the ignition coil is getting heat soaked to me.
Old May 10, 2001 | 08:47 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I have a fuel pressure gauge mounted inside my cowl hood.I have 12v going to the pump but the pump doesn't work so I know the pumps gone,? is why do they keep going out when temp gets around 200?
BD3
Old May 10, 2001 | 08:56 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Only thing I can think of right now is a fuel line touching or really close to an exhaust..Just for laughs what if you dont let the temp go over 200F?
Daz
Old May 10, 2001 | 10:17 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Daz it runs great,i drove it 2weeks ago to NYCriss's shop in S.I. and didn't have a problem but I never had any traffic either.
BD3
Old May 12, 2001 | 03:48 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Problem solved intermittant ground.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
