help I cant figure it out
Old May 11, 2001 | 08:36 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I have been working on my 89 5.7 Iroc for some time now and can not figure out whats keeping it from idleing. One day when I was coming home from work it lost power and started to putter off. It hasn't been able to keep an idle since then. I found that if I disconect the maf sensor however it will idle under what I understand is limp home mode. I tested all of the other sensors and they have come up ok. There is ground power to the maf sensor. I thought it might be the computer so I got one out of an 86' cavileer which supposedly was compatable. Pluged it up and it worked for about five minutes. The whole time it wasn't able to spit out codes or anything. I bought a new one and same problem. Could a bad maf sensor be causing all of this? Please help summers right around the corner and I need to get out with the t-tops off
Old May 12, 2001 | 09:47 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2"> I found that if I disconect the maf sensor however it will idle under what I understand is limp home mode. I tested all of the other sensors and they have come up ok. There is ground power to the maf sensor. . Could a bad maf sensor be causing all of this? [/B]</font>
if it idles better with the maf disconnected then its the maf.. buy a new one, not through gm though, unless you wanna get ripped off.
are you getting an ses light?
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
