Can some one identify this tpi unit?
Old Nov 23, 2007 | 10:02 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hey guys, i have been searching for days now, and i cant make the call whether or not this TPI/entire engine is from a 1986 iroc or a 1991 corvette. i kno i need to lok at casting #'s to see what the block/heads are from, but i kno there are visual differences to the tpi (egr, fule line angle ect, but i cannot make the call. thanks
link to the pics: https://www.thirdgen.org/forums/tech...ad#post3541906 (down towards the bottom)
Old Nov 23, 2007 | 10:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can some one identify this tpi unit?
Any rust on the heads?
Old Nov 23, 2007 | 10:11 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
there is rust on the valve covers, but not on the heads. the block appears to be repainted, so i kno it was rebuilt 4 years ago (the man i am buying the car from, on sunday hopefully, said so)
Old Nov 23, 2007 | 10:15 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
The easiest way is if you look at TPI runners on the driver side, and check if you have that little tube (circled in red) if you have it, you got 85 ~ 88 runners; if you don't, you got 89~92 runners. I hope this will help
Old Nov 23, 2007 | 10:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't have Corvette valvecovers, or Corvette accessories, and I don't see any sign of the Corvette external EGR setup. None of those things are definitive, though.
If he's selling the car, it's up to him to prove that it's a 1991 Corvette engine, not you.
Old Nov 23, 2007 | 10:18 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Good point
Old Nov 23, 2007 | 10:20 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thanks guys, especially 400z28 racer, that really should make it simple to tell about the tpi
Old Nov 23, 2007 | 10:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unlike a 1991 Corvette, that car has a MAF sensor, too.
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
That looks completely stock, but yeah, you'd have to check all that.
Fuel rails can tell as well.
Old Nov 23, 2007 | 10:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If the heads are painted, take a magnet with you and try to stick it to a bare spot on the heads. If it sticks, the heads are iron, not aluminum, and it's not a Corvette engine.
It's possible that parts of it may have come from a Corvette at some point, but that doesn't matter to what it is now, especially considering that the car doesn't seem to be running right.
It's also missing the A/C belt, which means that the A/C compressor or clutch probably isn't working either.
Old Nov 23, 2007 | 10:40 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
good idea! i'll have to do that on sunday. yeah he said the fuel injectors went bad, and then made the pump go bad, so i have to check those things out sunday too. its been sitting for 2 yrs now, and i think he may be trying to take advantage of me being 17 ans trying to BS me into paying wayyy too much for the car. any other tips to keep me from getting ripped off are appreciated, thanks
Old Nov 23, 2007 | 10:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Fuel injectors can't make a pump go bad.
Old Nov 23, 2007 | 10:50 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Don't buy this car.
Old Nov 23, 2007 | 11:02 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
fins on plenum come to far forward to be speed density setup speed density plenum ribs dont pass the front runner on the drivers side so this plenum has to be a mass air one ... and you dont see the mounting boss for the map sensor which is visible on a speed density plenum from the front.
you can see the fuel lines which come out on drivers side ... corvettes came straight out the front of the fuel rails on passengers side front of the tpi system.
runner dont have right texture to be a vettes vettes usually had rough texture in the last two years.
throttle body looks like a 90'ish one though. (accelerater cable setup)
Old Nov 23, 2007 | 11:04 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
haha yeah im thinking that its a bad idea. the situation is that once i buy the i'll have 6k to put into it, plus the money that i can save, so i'm torn because it has a nice exterior, i may just do a new engine trans, and go from there. i donno lol
Old Nov 23, 2007 | 11:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Looks like the 86 to me, there's no cam on it.
The induction system on that thing isn't from a Corvette, it's from the original 86 TPI. That's not an entirely bad thing though, there isn't much difference between the two. It might have Corvette aluminum heads (I'd bet no). It might also have a 350 in it, but that doesn't mean that it's a "Corvette engine" by any means.
You're not buying a car with a Corvette engine. You're buying a car with a possibly replaced, mixed 'n' matched dead engine, and dead engines all cost the same.
Tell the seller you want the car inspected by a reputable mechanic of your choice before you buy it. If he doesn't agree, then walk away. If he does agree to an inspection, then you'll have a much better idea of what you'd be up against buying it.
Old Nov 24, 2007 | 07:07 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Detail:
My '88 had the distributor cover (rear plenum extension) missing when I got it, so I went the a gm dealer to oder the part. The guy said there's 2 part number's one was for a platic piece which came on the Camaro, and the other is an aluminuim piece which was for the Corvette.
Of course I bought the alum piece.
Old Nov 24, 2007 | 11:29 PM
Guest
Guest
Posts: n/a
Someone's been in there at least, those are centerbolt heads. They didnt use those in 86. The rest is likely from the car, 86 intake and accessories.
Old Nov 26, 2007 | 07:59 AM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
I think '86 was a dual year for vette's early '86 vettes had iron heads as far as I know, I could be wrong tho, but this is true of a '91. Gotta watch that the guy didnt take the aluminum heads off for another engine. Those are pretty sought after heads. At least around here.
Old Dec 2, 2007 | 09:41 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hey guys, i took your advice, didnt buy the car, but i did find a 1992 b4c in near perfect condition that does run lol.thanks again, you guys are great
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Apr 14, 2016 08:52 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
Sanjay
Aug 12, 2015 03:41 PM
