Highest Lift on 85 LB9 heads
Old May 13, 2001 | 01:08 AM
Keith5's Avatar
Car: C1500
What is the max valve lift that I can get on an '85 LB9? I'll change the springs out I just want to know how high before my valve meets my piston.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
velcro t-top bag
*****Possible summer '01 mods*****
Wonder Bar from my IROC, 4th gen seats
1985 IROC-Z, TPI Auto
-Accel Super Coil
http://www.geocities.com/krt80/
Old May 13, 2001 | 02:00 AM
Guest
Guest
Posts: n/a
You will have a problem with the retainer/locks hitting the guide way before you will hit a piston. It varies from one head to the next, anywhere from .460 to around .500 lift. Only way to know for sure is to check it.
Old May 13, 2001 | 11:57 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I'll second that.
On the GM heads I have worked on, there is no "rule". Some had retainer to guide contact at .460" lift, others would handle 0.480. I am scared by the people who bolt on 1.6 rockers without checking clearances.
TO be safe, measure your heads! I forget, but you need to have a margin, so if 0.460 is max clearance, then you should not go higher than 0.440.
Mark.
Old May 13, 2001 | 07:20 PM
Keith5's Avatar
Car: C1500
Thanks I just wanted some idea, I'll check it out when I get there. I just want a little more lift so I probably won't have a problem.
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
happyhapka
Aug 15, 2015 04:42 PM
anesthes
Aug 8, 2015 09:37 PM
gwade12
Aug 8, 2015 08:17 AM
