Some help here guys with......Timing!?!
Old May 15, 2001 | 12:15 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I have read in many Pontiac HP Tech articles that you can bump the timing to as high as 12 degrees initial and see some strong performance gains. My question is if I do this how will it affect my engine in the long hall. It is driven on a regular basis and I am not to type to be under the hood everytime I want to go for a cruise. Any and all help would be great. Also what do you thin is the best timing to set the engine at??
Veiw MY CAR at:
http://www.members.tripod.com/~btessier
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 2.5" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Old May 15, 2001 | 12:27 PM
camarocowboy's Avatar
As long as you are not getting detonation (pinging)under acceleration you will be just fine,I have mine set at 10 now and have no problems.Your computer automaticly retards and advances as needed any way,but only so much.
Old May 15, 2001 | 01:33 PM
speed88's Avatar
Engine: 383
Thanks Camaro!!!
Veiw MY CAR at:
88 GTA
L98 350
700R4
3:27 axle
MODS,
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
