how to set my timing chain. zz4 concern
Old May 15, 2001 | 08:53 AM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
Where did you set your zz4 cam. Straight up or 4deg before or after. thanks
Old May 15, 2001 | 11:13 AM
camarocowboy's Avatar
On all sbc you always set your timing chain at dot to dot which is crank dot up and cam dot down if it is dot up dot up you will be 180 degrees out.
Old May 15, 2001 | 11:16 AM
Hank Brote's Avatar
Dot to Dot or Dot up dot down.......Makes no difference the cam travels twice for every turn of the crank..... I install them dot to dot for ease. What really matters is where TDC is for the distributor installation.
Hank
87'IROC Z28
Hanks 87 IROC
[This message has been edited by Hank Brote (edited May 15, 2001).]
Old May 15, 2001 | 03:14 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Travs timing chain sprocket has three keyways, one for straight up, one for four deg. before, and one for four deg. after. These are usually marked like A,B, and C.
Sorry I can't help you with your question Travs, I just wanted to clear up what you were asking vs. the dot to dot deal...
Old May 15, 2001 | 03:22 PM
FormulaJoe's Avatar
Well, a lot of it is going to depend on your other engine components (cam, heads, intake, etc.) Retarding the cam will give you a bit more power on the big end while advancing it will help you down low in the RPM range. So, it depends on whatcha got and whatcha wanna do with it. I wouldnt recommend going more than + or - 4 degrees.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
MY87LT
Aug 17, 2015 08:43 AM
