RPM
Old May 15, 2001 | 06:40 PM
BenDoe's Avatar
RPM
I was wondering with a 305 and the cam in the signiture, edelbrock TES headers, self tuned chip and a mild polished intake base, what RPM could i be spinning, and what should i do to get that RPM up to 6000RPM, thanks.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old May 15, 2001 | 10:18 PM
Vader's Avatar
Ben,
What valves and valve springs are you using? RPM is limited more by the inertial mass of the valve train and the spring's ability to control valve position, and less by the cam ramp or acceleration rates.
A lot of engines with lower lifts than that turn a lot higher RPMs (oval track cars), but they have the correct springs and a fuel system that can deliver at those rates.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 15, 2001 | 11:27 PM
BenDoe's Avatar
I don't know exactly what valves and springs i have, but i know that the valves are one step bigger than the 187 casting heads, and the springs are matched to the cam.
Old May 18, 2001 | 01:52 AM
silverstreakII's Avatar
<font face="Verdana, Arial" size="2">Originally posted by BenDoe:
one things staands out in my mind that seems to always allow higher rpms is a roller lifter, crane makes a great setup for it, saaw one with matched springs turn 7000 on a 355
</font>
Old May 18, 2001 | 09:04 AM
BenDoe's Avatar
I already have roller lifters, remember all post 87 GM's had roller lifters.
ULTM8Z
Oct 2, 2015 01:25 PM
Giocio
Oct 1, 2015 12:20 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
