Fuel pressure drops 6psi every 5 minutes....
Old May 20, 2001 | 07:56 PM
Like a ROC 89's Avatar
I have an '89 Iroc L98. It has 60k miles on it. I went to check the fuel pressure and primed the rails by turning the key on and off with the fuel pressure guage connected. It initially read 46psi but after about a minute it dropped 2psi and 5 minutes it read 40psi. It will probably be at zero in about 20minutes. I have checked the AFPR and it has no leaks, no leaks on new fuel guage eighter. I have heard that the TPI fuel rails should hold pressure for like 10hours. What could be wrong?
Thanks!!
Old May 20, 2001 | 10:35 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
That isn't entirely uncommon.
If you have no external leaks, then it is bleading of through a/some leaky injector/s or back through the fuel pump. If it doesn't black smoke out of the exhaust when you fire it up after it has been setting a while (bleeding pressure) then it is likely leaking back through the pump. Not a big deal unless it gets excessive.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
