Thinking about a Superram....I've got questions
Old May 20, 2001 | 10:24 AM
S10Wildside's Avatar
I've got a 355 TPI, Accel intake, ASM Runners, Ported Plenum, Edelbrock 52MM TB, and an AFPR. My truck (where the engine sits) is AWD and I have no traction problems, so low end torque gives me no problems. If I want to get out of the 14s, what is the best upgrade for my engine?
Should I replace the stock heads?
Should I replace the stock cam?
What would a Superram do for me...assuming I kept the 22# injectors, 52mm TB, stock cam, and heads?
Just looking for suggestions at this point. Thanks!
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, 1993 Typhoon Drivetrain
Old May 20, 2001 | 11:55 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
converter will help or spend cash and get heads to help it breathe.
Old May 20, 2001 | 06:54 PM
vortech305's Avatar
If your gonna get the superram say goodbye to your AS&M runners. The superram must include accels small runners. Since decreasing the size of the runners will give u a loss of torque but a gain in HP. MY opinion not worth it. Stay with your stock style TPI set up.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old May 21, 2001 | 12:10 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
with your list of picks i would go with better breathing heads 190 intake runner valume
or so.
heads will make the most differance
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old May 21, 2001 | 11:45 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Do this: a converter matched to the cam, a good street cam, and some heads. Why not do it all at once? Since this is a street truck (right?) and you have alot of $$$ in the intake, keep the setup you have. The super-ram is only good if you like beating the motor up alot, and if you push it to 5500+ RPM. Stock TPI can do the same if modified properly, but not to the same extent (HP). You gotta decide where the engine spends most of it's time. If you do get the SR, can I buy your intake for my '89 ( )? My '86 is getting a SR but I have yet to use it (waiting of the Vortec TPI base, damnit!)
Old May 21, 2001 | 11:49 AM
dhirocz's Avatar
extra page, sorry
[This message has been edited by dhirocz (edited May 21, 2001).]
dhirocz's Avatar
Now that I think of it, I gotta ask...I have seen this advertised but want to confirm it...does anybody notice a reduction in low-end torque with the SR? I am directing this to people who did nothing but swapped intakes, no heads or cam. I'm not the only one who wants to know.
Old May 22, 2001 | 01:33 PM
vortech305's Avatar
Yes there will be a reduction in torqe cause of the short runners that are required with the superram. LIke i said stick with the stock TPI unit. People spend well over $700.00 on the superram for nothing. NOt worth it unless your going with Really big cubic inches
92' camaro
Soon to come!!!
Other car;
Old May 23, 2001 | 03:58 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Going from a stock TPI to a SR with no other changes to my combo, I saw no real loss in low end torque. However, the gain in horsepower at the top was amazing. My car used to fall on it's face at 4300 rpm. Now it screams to close 6000 rpm. Huge improvement.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old May 24, 2001 | 06:03 PM
87iroczmd's Avatar
thirdgenfrank, did you run your car yet? if so what did it run?
Old May 25, 2001 | 08:35 AM
Engine: 406
Sorry, haven't run my car yet, Now I'm dealing with rearend problems. Making a lot more noise than I'd like (grinding). Since I don't have $2000+ to spend on a real rearend, I'm not sure what to do at this point. I guess I'll just put in new bearings, a gear, a TA girdle, and weld the axle tubes. Hope that will hold it until I get out of school and can afford a real rearend. I hope to have some times this summer since I'll be an hour from Indianapolis Raceway Park. I think launching the car will be the hard part.
Old May 25, 2001 | 11:15 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
The SuperRam is a midrange manifold. Hot Rod magazine did a comparative EFI test some years back and included OE TPI, big runner TPI, the SuperRam, and the miniram. The long runner TPI's had better low end and the miniram owned the 5500+ rpm range, but the 3500 - 5500 rpm belonged to the SR. I don't have the hard numbers handy but I can find them if you'd like.
I'd give AFR 190's consideration along with a moderate hydraulic roller cam.
The SR is not soft at low rpm's, though. Mine will break both rear tires loose in second from a 1500 rpm roll without touching the clutch. There's more torque than with the Dart/Performer RPM/Holley/222* flat tappet cam combination that it replaced.
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Jan 29, 2017 07:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
