crane 2032 cam...
Old May 24, 2001 | 07:06 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
crane 2032 cam...
I'm almost set on getting this cam for my 305 tpi - for the last year in a half i've been stuck with a peanut cam and my car went from being a mid-low 14 sec car to a mid 15 sec car(my old 305 had the l98 cam) - just wondering if anyone had a better suguestion for a cam... just remeber i have to worry about the ecm because of the speed density... thanks
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old May 24, 2001 | 08:33 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I've run the 2032 with 1.6 rockers for two years with great success. Not only is it a nice naturally aspirated cam, but it works excellent with nitrous and/or a supercharger. So if you plan on "upgrading" in the future, you won't need another cam.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old May 25, 2001 | 01:27 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
-willie are you using 1.6 intake and exhaust or 1.5 intake with 1.6 exhaust - I've been told that the car will idle like crap /w 1.6 intake - but then again you have a super charger...
Old May 25, 2001 | 08:25 AM
Willie's Avatar
I'm using 1.6 for intake and exhaust. I also have all mods that would be considered good for a 350, not a 305, such as a TPIS base, runners, ported plenum, 52mm TB, 1-3/4" headers, etc.
Yes, I run a supercharger but there are times when I remove it. Keep in mind that even when the SC is on the car, it runs in boost only two percent (or so) of the time. The car runs excellent naturally aspirated without the SC.
And Crane "suggests" NOT to use this cam on a 305!!! hmmmmm........
Willie
[This message has been edited by Willie (edited May 25, 2001).]
Old May 25, 2001 | 05:36 PM
Lounge Lizard 6's Avatar
Second what Willie said. I put 50k miles on my Crane 2032HR in my original LB9. Loved it. I also put an additional 20k on the same cam in my Trick Flow'd ZZ4. My only complaint with the current setup is, that it is just a little bit mild.
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Hotrodboba400
Dec 10, 2019 07:07 PM
thekurlyone
Sep 30, 2015 12:54 PM
alpine247
Sep 16, 2015 05:25 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
